Hello,
I have just received my PICAXE 28x2 module... my experience so far is a nightmare. I started using the Programming Editor for programming and communicating with the module but that was never been successful but very rarely.
before firing any questions I tried the WinAXEpad and for my surprise it is working very fine but in few times I need to reissue the commend (program/clear/...) twice or more.
as I have a PICO oscilloscope, I was able to monitor the behaviors of Serial Out (pin 0) and Serial In (pin 1) and my findings are:
1- WinAXEpad is able to release (or drop) Serial In to -8V after each communication with the PICAXE module
2- Programming Editor does not do the same
as you are recommending the Programming Editor (which I believe is better to use) I need your help with my issue.
regards,
Amr
regards,
Amr
