Hello all,
So I posted a program a while ago that showed the buttons statuses in a NES controller. I am now trying to switch this code over to a 20X2 (was working on an 08M2 before). There are two problems I am having. First is that when I try switching from the shiftin sub routine to the shiftin command, the program stop working. Second problem is that when I attempt to use other I/O for clk and data, it again stops working. Here is the last working code (already converted from 08M2):
Now when I comment out anything to do with the shiftin routine and try the shiftin command, it stops working:
Any ideas?
#rem
Updates
#endrem
' Constants
symbol bits = 8 'number of bits
symbol MSBvalue = 128 'MSBvalue (=128 for 8 bits,512 for 10 bits,
'2048 for 12 bits)
' Variables
symbol NESdata = b0 'holds NES button data
symbol counter = b1 'variable used during loop
symbol mask = w1 'bit masking variable
symbol var_in = w2 'data variable used during shiftin
' Pin Declarations
'Inputs:
symbol serdata = pinc.1 'serial data input
'Outputs:
symbol sclk = c.2 'clock output
symbol latch = c.4 'latch output
' Initialization
#picaxe 20x2 'tells compiler this code is used with a PICAXE 08M2 chip.
low sclk 'clock must be low before we can use the shiftin subroutine
low latch ;latch must be low before we can use the pulsout command
' Main
Main:
pulsout latch,1 'latch the data into the NES controller's 4021
'shiftin sclk,serdata,0,(var_in)
gosub Shiftin_LSB_Pre 'shift in the button data from the NES controller
let NESdata = var_in 'transfer shifted in bits to the variable NESdata
if bit0 = 0 then sertxd("A pressed ",cr,lf) endif
if bit1 = 0 then sertxd("B pressed ",cr,lf) endif
if bit2 = 0 then sertxd("Select pressed",cr,lf) endif
if bit3 = 0 then sertxd("Start pressed ",cr,lf) endif
if bit4 = 0 then sertxd("Up pressed ",cr,lf) endif
if bit5 = 0 then sertxd("Down pressed ",cr,lf) endif
if bit6 = 0 then sertxd("Left pressed ",cr,lf) endif
if bit7 = 0 then sertxd("Right pressed ",cr,lf) endif
pause 50
goto Main 'go back and check the NES controller buttons again
' Sub-Routines
' ***** Shiftin LSB first, Data Pre-Clock *****
' Shift in the data LSB first into variable var_in
' Read data before sending clock pulse
' Using clock output pin sclk
' Using data input pin serdata
'#rem
Shiftin_LSB_Pre:
let var_in = 0
for counter = 1 to bits ' number of bits
var_in = var_in / 2 ' shift right as LSB first
if serdata = 0 then skipLSBPre
var_in = var_in + MSBValue ' set MSB bit if serdata = 1
SkipLSBPre:
pulsout sclk,1 ' pulse clock to get next data bit
next counter
' #endrem
#rem
Updates
#endrem
' Constants
'2048 for 12 bits)
' Variables
' Pin Declarations
'Inputs:
symbol serdata = c.1 'serial data input
'Outputs:
' Initialization
' Main
Main:
shiftin sclk,serdata,1,(var_in)
'gosub Shiftin_LSB_Pre 'shift in the button data from the NES controller
pause 50
' Sub-Routines
#rem
Shiftin_LSB_Pre:
let var_in = 0
SkipLSBPre:
next counter
#endrem
