hi all,
I,ve started playing around with processing http://processing.org/ found this sketch processing on LMR that lets you control a servo or even leds , heres a link http://letsmakerobots.com/node/21878to" more on how the processing works".
If you gonna try this you need processing 1.5.1 later version gave me grief setting up serial on a 64 bit machine
here's the picaxe code that recieves the serial data to control the servo's:
the code is what i normally use a 10k pot that why the symbol analogvalue but this time i place the b0,b1 into the analogvalue which is recieved serial it's rough but it works.
and here' the sketch code for processing:
here.s a link to a quick vid:http://www.youtube.com/watch?v=B4f_BQ1Dntk&feature=plcp
#Picaxe 18m2
#No_Data
#com 1
symbol analogvalue1 = b0
symbol analogvalue2 = b1
symbol servoport0 = b.4
symbol servoport1 = b.5
symbol base = w10
symbol tilt = w11
init:
disconnect
servo servoport0, 150
servo servoport1, 150
pause 30
serrxd (13), b0,b1,b3
if analogvalue1 <> base then
servopos servoport0, analogvalue1
let base = analogvalue1
if analogvalue2 <> tilt then
servopos servoport1, analogvalue2
let tilt = analogvalue2
import processing.serial.*;
Serial port;
sliderV sV1, sV2, sV3;
color cor;
void setup() {
size(500, 500);
println("Available serial ports:");
println(Serial.list());
// check on the output monitor wich port is available on your machine
port = new Serial(this,"COM1", 4800);
// create 3 instances of the sliderV class
sV1 = new sliderV(100, 100, 90, 255, #FF0000);
sV2 = new sliderV(200, 100, 90, 255, #03FF00);
sV3 = new sliderV(300, 100, 90, 255, #009BFF);
void draw() {
background(0);
sV1.render();
sV2.render();
sV3.render();
// send sync character
// send the desired value
port.write(13);
delay (10);
port.write(sV1.p);
delay (10);
port.write(sV2.p);
delay (10);
port.write(sV3.p);
delay (10);
println (sV1.p +" "+sV2.p +" "+sV3.p);
Slider Class - www.guilhermemartins.net
based on www.anthonymattox.com slider class
class sliderV {
int x, y, w, h, p;
color cor;
boolean slide;
sliderV (int _x, int _y, int _w, int _h, color _cor) {
x = _x;
y = _y;
w = _w;
h = _h;
p = 150;
cor = _cor;
slide = true;
void render() {
fill(cor);
rect(x-1, y-4, w, h+10);
noStroke();
fill(0);
rect(x, h-p+y-5, w-2, 13);
fill(255);
text(p, x+2, h-p+y+6);
if (slide==true && mousePressed==true && mouseX<x+w && mouseX>x){
if ((mouseY<=y+h+150) && (mouseY>=y-150)) {
p = h-(mouseY-y);
if (p<0) {
p=0;
else if (p>h) {
p=h;
