Thanks for responding Technical
Sorry, cannot attach any one of the 55 flowcharts I have because the error message will not allow me to convert the flowchart to basic, let me explain.
Have used the "go sub command & Procedure command" in all flow charts and works very well.....and yes you are correct, a line does not have to be drawn between the two commands
Downloaded Editor V6.0.8.0 and the following problem started.
When running a flowchart program in the simulator a bright red error box pops up at the first "gosub command" in the program.
It states:
"error in cellxxxx (no where to go) Try redrawing the lines out of this cell"
Tried 8 different programs that have worked well in the past, all report the same error.
Tried creating new programs using V6.0.8.0 and same problem......it seems "gosub is not seeing procedure" is this a male/female thing and there're having a fight?
Please note, this does not seem to occur when programming in basic.
Possibly I should delete the Picaxe program and re-install
If that doesn't work, can I revert back to a previous version of the editor?
Thank you
As an aside, I've only been doing this for a year after retirement and thoroughly enjoy the benefits of Picaxe, the forum is awesome and all the moderators are to be commended.
