kittygobeep
download circuit problems!- even though test voltages measure correctly
I have a download circuit on a breadboard which I have been using successfully for almost a year. A couple of months ago when I used it last, it was fine. Now, apparently the hardware can't be found - but when I perform the test, I can measure the correct voltages between serial-in and ground. The correct COM port is definitely connected and I've checked all the download circuit connections! I'm using a PICAXE-18. Has anyone encountered this kind of thing before?? Thanks in advance for any suggestions...
