Hello all
haven't posted in a while. What is the ambient operating temperatures for the Picaxe and the CHI030 boards?
I use CHI030 with 18M2+ chips for a variety of Halloween props, and I am having all sorts of issues with programs not running properly once they get into cool temperatures.
I will program a CHI030 board (I have several that I use for different props and applications) and everything will run perfectly on the bench, at room temperature. But when that board goes outside (in a protective container to keep out moisture, of course), and where the ambient temp is between 0 and 8 degrees Celsius, the program does not behave properly at all. Pins will be turned on that shouldn't be, pins that should be on are not, programs that should be turning pins on and off for a certain amount of time will only run for a couple of seconds. I tried switching out the darlington drivers, with success on one board but not on the others. I tried downloading the same programs into the respective boards, doing hard resets, all to no avail. I also tried adding hand warmers to try and get the temp up, but I don't think they got warm enough to make a difference. Has anybody else had these issues and is there a way to resolve them?
The CHI030 boards a running either 12VDC pneumatic solenoids (which have a very small current draw), are switching 12VDC relays, or are running LEDs ( again very low current).
Just to be clear, I have several props that use picaxe chips that are NOT in CHI030 boards, and they don't seem to have the same problems at the low temps. it seems to be specific to the CHI030 boards.
Thanks in advance for your help.
