Hi folks hope you can help out. Have been working on a Halloween project. Have circuit built, have checked solders and continuity through out circuit and all is as it should be. However, when I go to download program, i recieve "Error: Hardware not found". I followed the instructions from page 8 of the first manual, carefully ensuring that a, b and c on the download cable match up with the appropriate parts of the female jack. I have checked continuity from jack to pins and all checks out. The resistors are showing the correct values and i am getting 5v to the 18M2. i have a 0.1uf cap soldered directly across the 5V and 0V pins. When the chip is in a CHI030 board, it accepts the download. I have put the chip on a breadboard and get the same error message. I have tried 3 different female jacks, all with the same result. Not sure what to do.
I recently downloaded a newer version of the programming editor, as I purchased a 14M2 and the version I had did not support it.
