Hi forum,
I need help with interfacing the Maxim 6675 thermolcouple to digital converter.
1) my home project is, eventually, the climate control of my house. For the moment I am concentrating to measuring and logging the temperature of the bricks in the storage heater. They reach up to 550 degC (multimeter reading)
2) I haven't much experience in electronics, .... but I keep reading.
5) For the moment I am prototyping with an AXE22P prototype board with a 40X1, (customized as Westaust55) and a breadboard carrying the 6675, mounted on an adaptor board.
See picture.
The picture does not show it clearly, but the outputs 6 and 5 of are used to drive the CS and SCK signals for the serial protocol of the MAxim chip.
The Maxim output is collected by input 5 of the 40X1.
The 6675 datasheet is:
http://datasheets.maxim-ic.com/en/ds/MAX6675.pdf
My code is the minimum to test the interfacing:
I have taken it from P Anderson site. From what I can understand the code is compatible with the serial protocol from the datasheet, but I need confirmation please.
Now the problem:
I see fluctuating, somewhat random readings. I display them either with a "debug" command or to the AXE33 LCD display.
I see the value of TEMP varying from zero (most of the time) to 16, to 4, to 2, to 3, to whatever. The temperature should be ~20 degC, constant, as the thermocouple tip is on my desk.
The microcontroller works, it can download the software and light LED (not shown), etc.
I have two MAX6675 and they both behave in a similar way. I have been careful and quick in soldering it to the adaptor board and I believe the soldering is OK, with no bridges, bu how can I check?.
If I measure the voltage from the thermocouple directly on the breadboard and I heat the tip with my fingers I see the voltage moving by several mV, but the value of TEMP does not vary accordingly.
I don't have an oscilloscope to inspect the connection between the Picaxe and the MAX, so I am looking for advice on whether my code is right and what tests to carry out next.
Thanks in advance
Riccardo
See picture.
Now the problem:
Thanks in advance
Riccardo
