I'm having some issues here that I don't quite understand. I've been working on a RGB LED project for an annual Halloween party. I have an old PC power supply that I've modified with a toggle switch so I can use it as a project power source. It great because it has multiple voltages and high current ratings.
Now for the problem. I built my setup using three PWM outputs on a 20M2. Those outputs are wired to three MOSFETs for the high current draw that I'm expecting. Nothing fancy about that. Every thing works great with one or two LEDs strips (5M with 300 LEDs). I can turn on and mix of colors and fade them at will. The problem comes into play when I start adding more strips. When I get to about three strips, I start hearing a high pitch sound coming from the power supply. Logic says that it's noise from the PWMs. The more strips I put one the louder it gets and soon after the power supply shuts down completely. It has to be caused by the noise being generated but why? I'm positive that it's not a current issue. Each strip with all three colors on at 100% is about 0.7 amps. Thats a total of 2.8 amps on a 17 amps (at 12V) power supply. Any ideas of a solution or in sites on a suitable power supply that with handle the possibility of 14 amps (yes I know that a lot of strips)?
Image of my project board.
