I have a circuit I have been working on that has a picaxe 18X, a ds1307 clock, an LCD, an LCD driver (a PIC microcontroller). The LCD, LCD driver and the ds1307 only need supply voltage during the first minute or so of operation. After that, the picaxe switches off the supply to those parts to save power.
(They are powered through 18X output pins).
My question is: Will the various resistors that are pulled high by a connection to the main power rail still cause some power drain or is it sufficient to only switch off the supply voltage?
I will do some testing but thought I would ask here also.
Thank you!
Thank you!
