I'm havuing a little trouble with my POV project. Essentiaslly the LEDs don't light. Essentially its the same as the AXE135 except its built on a KiWi board, the LEDs are blue (2.0 VDC drop, 20 ma), and I'm using 180 ohm resistors instead of the 330 ohm resistors used in the AXE 135 kit. Initially I put the entire program together as listed, except that I used 27 sub-routines, one for each of the letters of the alphabet and the other for the heart symbol. The program editor provided no errors. I then read in one of the PIXAXE forums that there was a subroutine limit of 15, but that applies to the 20M, not the 20M2 I'm using. I did strip down the number of subroutuiines for trouble shooting purposes though. Still no luck. Finally I loaded the test program below, and only B0, B1, and B4 LED's lit up very breifly. After repeating the depression of the button, only B1 and B4 lit. After waiting a few seconds, I could get the initial three to flash.
Instead of remaining lit for 2 seconds, all I got was a brief flash.
Am I asking to much power from the 20M2? (8 x 20ma). If I am, what's the maximum I could get out of 8 LED, all which could be lit simultaniously?
The schematic can be found on page 4 of http://www.picaxe.com/docs/AXE135.pdf
The full program I initially used is below. I also replaced the "let pins = %00111111 (sample) with let outpinsB = %00111111 with no affect.
#Picaxe 20M2
if pin3 = 1 then do_message ; wait for button push
goto main ; loop until buton push
do_message: : light LEDs
let pins = %11111111 ; test LED all on
pause 2000 ; delay all LEDs on for two seconds
return : loop back
#Picaxe 20M2
dirsB = $FF ; set all B pins as output
' start:
setfreq m8 ; double Picaxe speed
main: ; return point on loop
if pin3 = 1 then do_message ; wait for switch depression
goto main ; wait for button depression
do_message: ; begine actual message
pause 300 ; Delay beween switch depression and first character
gosub letter_E ; letter E in message
gosub letter_D;; letter D in message
gosub letter_D ; Letter D in message
gosub letter_I ; Letter I in message
goto main ; loop back waiting for button depression again
letter_a:; Data subsoutines for letters A though Z
pause 2 ; Pause before first LED string lights
pause 2
let outpinsB = %01001000
pause 4
pause 2
let outpinsB = %00000000
letter_b:
pause 2
let outpinsB = %00111110
pause 2
let outpinsB = %01001001
pause 4
let outpinsB = %01111111
pause 2
letter_c:
pause 2
pause 2
let outpinsB = %01000001
pause 6
letter_d:
pause 2
pause 2
pause 3
let outpinsB = %00100010
pause 2
let outpinsB = %00011100
pause 1
letter_e:
pause 2
pause 2
pause 3
pause 2
letter_f:
pause 2
pause 2
pause 4
let outpinsB = %01000000
pause 1
letter_g:
pause 2
pause 2
pause 1
pause 2
let outpinsB = %01001110
pause 2
letter_h:
pause 2
pause 1
let outpinsB = %00001000
pause 4
pause 1
letter_i:
pause 2
pause 1
pause 2
pause 1
letter_j:
pause 2
pause 2
pause 2
pause 2
let outpinsB = %01000010
pause 1
letter_k:
pause 2
pause 2
pause 1
let outpinsB = %00010100
pause 1
pause 1
pause 1
letter_l:
pause 2
let outpinsB = %00000001
pause 4
pause 2
letter_m:
pause 2
pause 2
let outpinsB = %00100000
pause 1
let outpinsB = %00010000
pause 1
pause 1
let outpinsB = %00000100
pause 1
let outpinsB = %00000010
pause 1
pause 1
pause 1
pause 1
pause 1
pause 2
letter_n:
pause 2
pause 2
pause 1
pause 1
pause 1
pause 1
let outpinsB = %01111110
pause 2
letter_o:
pause 2
pause 2
pause 4
pause 2
letter_p:
pause 2
pause 2
pause 2
let outpinsB = %01111000
pause 2
letter_q:
pause 2
pause 2
pause 1
let outpinsB = %01000101
pause 1
let outpinsB = %01000011
pause 1
pause 2
letter_r:
pause 2
pause 2
let outpinsB = %01001100
pause 1
let outpinsB = %01001010
pause 1
pause 1
letter_s:
pause 2
let outpinsB = %00111001
pause 2
let outpinsB = %00010001
pause 1
pause 1
let outpinsB = %00100111
pause 2
letter_t:
pause 2
pause 2
pause 2
pause 2
letter_u:
pause 2
pause 1
pause 2
pause 1
letter_v:
pause 2
let outpinsB = %01100000
pause 2
pause 1
pause 1
pause 1
let outpinsB = %00000011
pause 1
pause 1
pause 1
pause 1
pause 1
pause 1
pause 2
letter_w:
pause 2
pause 1
pause 1
pause 1
pause 1
pause 1
pause 1
pause 1
letter_x:
pause 2
pause 1
pause 1
pause 1
pause 1
pause 1
pause 1
pause 1
letter_y:
pause 2
pause 2
pause 1
let outpinsB = %00011111
pause 1
pause 1
pause 1
letter_z:
pause 2
pause 1
let outpinsB = %01100001
pause 1
let outpinsB = %01010001
pause 1
pause 1
pause 1
pause 1
