Alex Leech
Hey all !!!
Background knowledge:
I have built a project that uses a 28x1 chip, has 7 inputs that are all push to make switches, 8 LED outputs and 4 100K potentiometers.
I also have a midi output that is working with the computer perfectly.
(see thread http://www.picaxeforum.co.uk/showthread.php?t=13403 )
The Project is a control surface for certain music programs on the computer that read the midi data comming in and then use it to change values e.g. volume
The Problem:
I am sending out the data being read from the potentiometers after it has been halved (potentiometers are 0-255 where as midi is 0 to 127 so its roughly right when halved) but where the potentiometers are flicking between 2 values most of the time im getting constant streams of data from the 4 potentiometers which is locking up the system a bit !!!
Is there any possible way of avoiding this ????
Cheers !!
Alex
The Problem:
Cheers !!
Alex
