Pauldesign
I've been struggling to send and receive IR coded signals using the multitasking feature of the 18M2.
Have some body done this before? and if not, is it possible to accomplish this using just a single 18M2.
In the interim, i've sent IR signal using Task 0 program (which is working) and i can detect the signal on the IR received pin using an LED.
By just using only one task in 18M2, i can also transmit and receive IR signals (by checking for a pin state) but not coded data but i can't decode the coded transmitted data.
I can troubleshoot it if is a code bug but all i inquiring is, is it possible and straight forward without any complex coding to achieve it?
Rgds
Rgds
