I am close to making the PCB for my weather toy. I would appreciate it if you could have a look at the attached PCB idea before I commit it to the pot.
I have used Diptrace, my first attempt at the application. The view is from the component side.
It is based on the Picaxe datalogger. The vertical row of pins on the left are for the 433mhz RX, antenna extrepe top L. The picaxe is the 18x, with the RTC. The SDA & RTC are taken out to a 4 pin header, and then the FRM 101 serial chip is on the right.
At first I was concerned thet the "silk" did not show the component connections, but it all seems to tally up.......unless I've missed something.
Thanks, Russ
Thanks, Russ
