Hi, I'm doing an animatronic creature and for laughts I thought it'd be good to controll the animatronics via a Playstation (1 or 2) controller or an old NES Advantage Arcade pad... I use the PICAXE 28X1 board and have used it before to make an animatronic head (See attached Image)
I've done a little research on the PS2 controller (or PSX as they seem to be reffered to) and I've found that it's not so straight forward, it doesn't have the simple in and outputs I'd like... I'm not very electronics literate so the link below may help you understand...
http://www.gamesx.com/controldata/psxcont/psxcont.htm
I'm sure that even though the NES Advantage controller is older and therefore simpler in design it will still not be so straight forward...
I was wondering if there is any way to program the PICAXE 28X1 to decode the Playstation controller and use it as an input device?
The NES Advantage seems prety straight forward and shouldn't be so hard to hook up to the PICAXE inputs so I'll worry about that if there's no hope for the PS controller...
I have put my own buttons and that into an older Playstation controller with success but surely it'd be more fun to be able to plug any old playstation 2 controller into the PICAXE right? .
Many thanks and please ask for any more details, I will do my best to answer them.
