I've got a circuit (w/ 28X1) which use a 0-5V voltage input from my cars' ECU (but the 28X1 is powered from a separate circuit in the car) and when I power off the uC with a manual switch, the car engine cuts out. I think there is some kind of feedback getting to the ECU which it doesn't like. It seems like it may be pulling down that line once it is shut off. There are no leaks to ground on the PCB, as the track from the voltage input terminal block goes directly to the uC and is NOT connected to any other tracks on the PCB (professionally made PCB btw)
Does anyone have any suggestion to whether I can use eg. rectifier or other diode to stop any signal / feedback getting from my circuit back to the ECU? Or suggestions on what it could be casuing this?
Regards,
Alan in Oz
Regards,
Alan in Oz
