i put my 08M proto board together and tried to make out the pins on the chip. Lucky I did because I thought that the numbering was straight forward i.e. the 08M I would count, from top left 1,2,3,4, then the other side from bottom to top 5,6,7,8. When I read the instructions I noticed that the connecting pins were not what I thought. It was printed to the out side of the chip starting top left and going anti-clockwise (pin) 1 - +V, (pin) 2 - Serial in, (pin) 3 - Pin4, (pin) 4 - Pin3, and the other side from bottom to top (pin) 5 - Pin2, (pin) 6 - Pin1, (pin) 7 - Pim0/Serial out, (pin) 8 - pin0V.
I nearly put the wire connections in the wrong place, I've got it sorted - I thought. On looking through 'picaxe' book and any other areas that showed the pins (like the picaxe 08) 1 to 4 one side and 5 to 8 on the other. I thought myself 'is this wrong', most likely its not so it brought back my confusion. Where do I find out a fool proof way of getting it right?
