As always, wanted to say thanks for those that are interested enough to follow this thread and offer help.
Armp wrote>>>The photos indicate you're not putting the test lead from emitter to GND<<<
The pic of the completed project is misleading as the black wire is not a power supply GND. I am, in effect, just adding 18" of wire to make the rig work.
Dippy wrote>>>>but what voltage is the motor rated?<<<
Stamped with 3-6V. It has a cap and a diode connected to the output terminals. (It came from one of those Sharper Image hand messagers)
Dippy wrote>>>C2: Stick 100nF Ceramic as close to PICAXE power pins as possible.<<<
Easy to do and makes a lot of sense. I will work that in. See my 'scope comment below.
Dippy wrote:>>>Also some kind of 'reservoir' cap where the motor is<<<
Dippy, I assume you mean cap in parallel with the motor?
Dippy wrote:>>> consider an N MOSFET for the motor switching. I'm not a Darlington fan.<<<
Me either (anymore). This is one of the best learnings I have gotten from the project. I need a few MOSFETs in my kit for switching. This is a change I will make regardless of if I get the current setup to work or not.
Texasclodhopper wrote:>>>An oscilloscope is essential. (I looked at your blog, and you have electronic projects going back for years. I guess you were just lucky enough to have never needed an oscope for one of those.)<<<
Hey, thanks for checking out my project page! I do have a 'scope and used it to put up some signals from the piezo in post #9 of this thread. I have put it on the transistor output as well. When the transistor is off, I do see a bit of 60Hz noise (see bypass cap reference above). Other than that, the signal is nice and squared when the motor turns on and off (with emphasis on the word *when*).
So... back to the lab to try a few things. I will probably swing by a Radio Shack and pay the outrageous $2 for a MOSFET. Oh, how I long for the days when the local Radio Shack catered to the hobbyist nerd in all of us....
Thanks again and I will post up the results.
