alistairsam
I've completed a few projects where the circuit board is housed in a plastic box and needs to operate outdoors at close to 0 deg C ambient with medium to high humidity and have found that they behave erronously as the temperature drops.
I had a read of the microchip datasheet and the max ambient range is -40C to +125C, so it is well within tolerance.
Is this normal or expected and if so would I need to maybe insulate the box?
came across this thread as well http://www.picaxeforum.co.uk/showthread.php?12932-PICAXE-stability-vs-operating-temperature
I'm using 28x2's, 20x2's and 20m2's and they've all operated perfectly indoors on my work bench but when I use it outdoors, it starts behaving erratically after an hour or so. eg, a 28x2 as a simple pulse generator for a stepper controller, works perfectly inside, but outside, starts pulsing erratically or stops after an hour.
another 20m2 as a dew controller driving FET's, same thing, stopped pulsing (not using pwmout), but started after a power reset and then stopped after a while.
I'm using them with telescopes, so they're mounted in a jiffy box that's not airtight, but doesn't get damp inside even if there's heavy dew.
any suggestions?
What should I test?
power supply is via a 5v voltage regulator. I've used a 9v DC adaptor as well as a 9v battery.
any suggestions?
What should I test?
