Hi. I am trying to make a sound detector for my picaxe. I made the picaxe_sound cicuit three times on breadbord. But i cant get a output signal as it says. I checked with meter, everytime it shows defferent constantan volt on output.
Did you follow the adjustment procedure? In a low noise environment, adjust RV2 until the output is high (3.5v), then adjust the other way until goes to near 0v. If adjusting RV2 does not change the voltage from 3.5 to 0v then the circuit is improperly assembled.
Can you tell me what is output volt, like is it +v or -v ?
The output will be anywhere from 0v to about 3.5v, depending upon the positions of RV1, RV2 and the sound level.
I dont understand the Third part of circuit. the third transistor is npn and the output is not on right place, i mean pin C of the trasistor should be the output...."
You are mistaken. The output is correct. It is an emitter follower. The voltage at the emitter will "follow" the voltage at the base.
Attached is a diagram that breaks the circuit into 3 stages. Build stage 2 and 3 only. After it is done, put your meter on the output. Then adjust RV2 and see if the voltage changes from 0v to 3.5 v. If it does not, then you have misplaced a component, have something backwards, used the wrong value component, or wired something incorrectly. Once you have this working then build stage 1 and connect it to stage 2. Adjust RV1 for best operation.
You may want to change C4 to a smaller value for testing. When there is sound, C4 will charge and keep the output HIGH for about 1/2 second even after the sound stops. A smaller value will allow the output to reset to 0v faster after the sound event ends. I would suggest 100nf.
If you still cannot get it working, then you will need to take a close up and clear photo of your breadboard and post it here on the forum. The photo should be taken from directly above the breadboard so that everything can be seen. If you do not provide a photo then you will likely not get any more help as there is nothing more anyone can do without it.
