WHITEKNUCKLES
In radiogareth's thread on 06-04-20013
I posted
I have been trying to use the convert to assembler function with the programmer attached but get "Error 53" then "compiler path invalid" then :\.........\picprog\wstamp16.exe"
Technical's comment.
wstamp16 is an old 16 bit exe, and so won't run on modern 64 bit systems. It will be updated in PE6.
I have tried again to use the convert to assembler function with the programmer attached but this time using a Windows XP laptop with the following result.
"Error 53" then
"c:\Program files\programming editor\picprog\wstamp16.exe"
The programmer functions properly using Hex files from a different compiler.
I would appreciate any help.
Dave
I posted
"Error 53" then
Dave
