ElectronicsFairy
Hi everyone. Newbie here
I'm currently studying A2 Electronics, and my teacher is trying to think of ideas for projects. Today he got me to see whether we could use the EPROM memory on a PICAXE-18A for a project. I discovered that it was too impractical, but am wondering if anyone could point out an easier way
The idea was as follows :-
To feed in 4 bits serially to the PIC and WRITE this value to an address in the EPROM. Then READ that address and OUTPUT it when necessary.
The problem I found was that the WRITE command needs the user to specify the value to be stored - either a Variable from A-H, or a number from 0 to 255.
As the user will not know what the value of the 4-bit serial input will be, we didnt think the WRITE command would work, and instead it would need an EPIC flowchart considering all possible values. Even only using 2 bits, it would be huge.
So my question is whether anyone can think of a way to write the flowchart more easily, or whether it really is too much for an A2 project.
Btw, we're running the PIC Logicator software on XP Professional on a school database and as stated above, it's a PICAXE-18A.
Many thanks.
Ben
Many thanks.
Ben
