PICAXE "time" variable vs clock frequency
Under the instructions "enabletime" and "disabletime" the PICAXE PDF states that:
It is inconsistent about 16MHz. In fact the last statement is false.
Instuction tests
Instructions were timed using variations of the following code, using 10000, 20000, 40000 or 50000 for n:
w3=time
for w6=1 to n
next
w4=time
for w6=1 to n
instruction under test
next
w5=time
us=microseconds. Times are +/- 100us
Symbol: | k31 | k250 | k500 | m1 | m2 | m4 | m8 | m16 | m32 |
Actual frequency: | 31kHz | 250kHz | 500kHz | 1MHz | 2MHz | 4MHz | 8MHz | 16HMz | 32MHz |
Time increments every: | untested | untested | 33.3s | 16.7s | 2s | 1s | 2s | 1s | 0.5s |
Assumed frequency: | untested | untested | 15kHz | 60kHz | 4MHz | 4MHz | 16MHz | 16MHz | 16MHz |
Effect of increased clock speed:
The time function will work correctly at 4MHz or 16 MHz.
At 2MHz or 8MHz the interval will be 2s.
At 16MHz the interval will be 0.5s
Instuction tests
w3=time
for w6=1 to n
next
w4=time
for w6=1 to n
next
w5=time
Instruction Under Test (IUT) | IUT Time | Clock |
