I am trying to read the Picaxe GPS into a Picaxe 40X on the proto board. Power is supplied by two separate 4.5V battery supplies.
The GPS is outputting data okay when fed directly into the PC's serial port.
I have put a sertxd statement as the first line of the program to test the connection and it work okay when the GPS is not connected.
When the GPS is connected to input pin 1 (TTL level), the Picaxe hangs and the program does not run. I also cannot program the Picaxe when the GPS is connected.
I've looked at the GPS output voltage and it is only 2V (measured on a scope).
Any suggestions would be much appreciated.
