I'VE GOT IT!!!!!
All that's left is to perfect some resistor values, which appear to be critical.
The circuit works exactly as predicted, perfect control and good regulation from about 1.6 volts up to about 22 volts on a 24 volt supply. Poor low end attributable to pot that doesn't go to full ground plus mosfet that is, at best, 1.8ohms, and then the error is multiplied by the ratio of the resistor chain. It locks up above 22 volts, but that can be figured out and corrected in software or hardware, not sure which yet. Edit: I have some HUF76407D3 with rDS of 0.107 ohms -- will give them a try tomorrow.
317 is not on a heatsink so didn't try a lot of current, but enough to make a 300 ohm 1/4 watt resistor really, really hot while the 317 got just a little warm. Also no input/output capacitors on the 317 so maybe some instability in my test circuit.
There is no need to put the feedback resistor chain on the output -- it can connect to the adjust pin along with the 2N7000.
The secret (drum roll, please) is in the values of the various resistors. I finally used 1 meg and 3.3 meg for the feedback chain, and that
seemed to work and worked better with a jumper rather than resistor from the junction of the resistors to the 08M input so, obviously, the resistor values in the chain might/must be adjusted down, but carefully. If the values are too low, the circuit doesn't work for me.
Also, appears that the pullup resistor I mentioned is not required. (EDIT: Wait, I think I take this back. I think I did use a pullup from adjust to input pins, 10K. I'll verify when I go back to my workshop tomorrow.
I put a 220 ohm between output and adjust (didn't have a 240).
So, that's it, a done deal. Haxby, are you reading this??
