harvey_twyman
We have 1 older PICAxe 28X1 device with Firmware Version A3
This programs at 5V under Vista correctly.
The newer 28X1 devices I'm having problems with have Firmware Version 5
The devices initially reported their firmware using the
"Options/Mode/Firmware?" command correctly but wouldn't program
with the error message:
"Error - Memory Verification Failed (Byte 255)"
After repeated trials with supply voltages down to 4.5V
I managed to get them to program successfully.
However after several programming sessions at these lower voltages
the devices DIE! The firmware command then returns a message:
"Error - Hardware not found on COM"
All your datasheets mention using 5V suppply so why do
Technical Support always suggest using 4.5V to power the device?
We've used these chips powered by a regulated 5V supply for
several years now without any problems.
So what's changed? - the Firmware!
I've managed to KILL 5 devices so far!
Harvey Twyman
Department of Electronics
University of Kent
Harvey Twyman
University of Kent
