Hi guys,
I have recently had to delve into my stash of older Picaxe chips as I had burned out my newer ones (don't ask) - These are probably circa 2010
I have found that HPWM Mode 1 is not working correctly on these two older chips. The 'high' side output is working on Pin c.5 but there is no output on the 'low' side pin c.4
For example:
setfreq m64
HPWM 1, pwmHHHH,1,249,800
should give me an output on the high (c.5) and low pin (c.4) at 64khz, opposite to one another, at approx 80% duty cycle.
Only the high side is working. No sign of life on the low side, when measured with an oscilloscope or multimeter.
If I do a HIGH c.4, the output works, so the pin appears to be okay.
This was working fine with the newer Picaxe 20x2's I had. So i'm wondering if there was a problem with earlier Picaxe 20x2's or they changed the way HPWM functions.. or am I just unlucky and have two faulty Picaxe chips?
Cheers,
Adrian
For example:
setfreq m64
Cheers,
Adrian
