9-AUG-08
Sub tropics – Outback Australia.
I was notified at 7:30pm at night that the transmitter at our local Amateur Radio repeater was stuck on. This was after our first fears lightning storm of the year went through earlier in the day around lunchtime.
I went to the repeater site and found the PICAXE-18X in the repeater controller card had pretty much "lost its way". No all, but most of the outputs were ON for no reason. Unfortunately the “PTT” (Push To Talk) to key up the TX radio was one of the outputs that was on. I reset all the power and the PICAXE based repeater controller seems to have come good. I also let the TX radio cool down for half an hour as it was probably on continuously for 5 - 6 hours! (The unintentional 100 percent duty cycle check on the TX radio and it's heat sink are now complete!!!
My questions:
What possibly happened to the PICAXE-18X??? It was just stuck in this state and was unresponsive to any DTMF commands I sent to it via my hand held VHF transceiver or anything I did until I resent the power. ((The RX radios squelch was not open. (no sound out of it's speaker) So the repeater was not in use. So no outputs should of been on.))
I would of thought the PICAXE works or it doesn’t. Why would a power reset fix this problem?
Is a PICAXE more susceptible to something like this since it has…. how would you say this…. bootstrap code in it?
Are PICs in general more susceptible to this sort of problem vs. STAMPS, AVR’s etc.
Should I really expect better results from the PICAXE or any sort of micro, PIC, IC etc. etc. as our suitably earthed radio tower and building probably took a direct hit of tens of millions of volts at tens of thousands of amps!
In my code I have a timer (more like a counter) to shut the TX radio off if it is keyed up for a long period of time. It’s presently set to 10 minutes. This feature works perfect under normal operation. But it’s now proven that I can’t count on this feature to shut the TX radio off if it transmits for extended periods of time when the PICAXE “looses its way”. Possibly I need something external to the PICAXE to sense the transmitter current draw and shut the TX radio off if it transmits for a long period. But this will probably be some sort of electronic and mechanical relay system which is susceptible to a lightning strike too. Possibly this is really a no win situation? Does the PICAXE vs. mother nature really have a chance!?!?!
One good thing to note, at least I didn’t have to replace a dead PICAXE!
"HamRadioAddict"
My questions:
"HamRadioAddict"
