andrefcarvalho
Posts merged from other forums / threads and edited to try and make some coherent sense
Nor do I as I've not studied the datasheet nor have the hardware. I imagine it would be possible to program the programmable character RAM within the chip to create the pattern needed for the segments you are controlling but I haven't really investigated that.therefore
but this would have to get on and off each outlet of mas6953 and do not know how
From a quick initial look at the MAX6953 chip I saw that the command byte/address had bits D8 to D15 identified.The firmware version is 2.B, why question the version?
i2cslave %10100000,i2cslow,i2cbyte ;set the slave address, i2cspeed, etc
start:
writei2c ($04,%00000001) ;write to the configuration register ($04) and change the last bit for normal operation
writei2c ($60,"E") ;write to digit 0 ($60) the letter E
writei2c ($01,$0F) ;change the brightness to full on that digit ($01 intensity register)($0F full brightness)
I had never remembered seeing this chip, maybe I will instead seek to achieve this in relation to max6953 I can handle an array of 5x7 easily agoa the hard and control the display, even if serious record in memory as I indicated ....Also, the MAX6955 is an i2c interface based multi-segment LED driver that can accept multiple 16-segment LED displays:
http://datasheets.maxim-ic.com/en/ds/MAX6955.pdf
