I have push buttons wired to the inputs of the 14M. The inputs are tied to +5VDC through a 10K resistor. When the button is pushed, it grounds the input taking the pin low.
On the "In 3" input (pin4), sometimes, just touching the the lead hooked to the button
makes the PixAxe reset. This does NOT happen with any of the other inputs. I am
positive the circuit is reseting because altered the code to output a sound when the
circuit reset, (just for testing purposes).
Any ideas? How can I stop this. And, why does it just happen on input 3 and none
of the other inputs as they are all wired the same.
I also tried changing the 10K resistor to a 1K resistor and it did not help.
Thanks,
Mark
Thanks,
Mark
