Hi there,
When programming in assembler code in PE set to PIC16F88, the __config directive doesn't seem to accept any configuration value, including the defaults and including b'1111111111111111'. I have made a custom p16f88.inc file as correctly as I could, and I re-checked the config section and it is correct with the datasheet.
It always reports "Error[126] : Argument out of range (not a valid config register address)" on the __config line.
The config works ok with a PIC12F683 and other assembler programs.
My workaround is to have no __config directive in the assembler program, compile it to HEX without programming it onto the PIC, then I set the configuration settings manually in the PIC programmer which I then program the PIC with. I have no other errors or problems and my last PIC16F88 assembler program (basically testing bitbang serial output) works as intended.
