a search is underway. for some code.
it would be equal to what Parallax has already done in BS-2 syntax.
file = 433Radio2WayTX-V1.2.bs2 updated 10-08-2009
this example code file for the 27982 shows how to send
packets of 1 to 16 bytes of data in duplex mode.
between 2 transceivers. with error checking
the duplex is so the transmission errors will be at a minimum.
every byte is tested by the Rx w/ CRC checksum code and reported to
the Tx as good or bad. a second byte wont be sent until the one
before it was received as good.
rather than go to the trouble to translate the BS-2 code into pic.
a search is underway for it being done already.
if you have seen this done anywhere let me know.
this file code ex. of duplex transmission is a quantum jump more complex than another packet ex. they publish in simplex mode also for their BS-2
at this point i'm not even sure the
pic language can do it.
this effort has made me aware of how a language is developed
in accordance with what people are trying to use if for
given picaxe's lack of support for rf & data telemetry it could be smarter
to just get a couple of BS-2 chips
