I asked about persistent SerTxd transmission when the power supply to a Picaxe circuit was disconnected. The details are here,
http://www.picaxeforum.co.uk/showthread.php?20601-CP2102-Puzzle
The answer was that it had something to do with flow control relative to the USB adapter, but it has nothing to do with flow control. I am using this exact Goeytex circuit,
http://www.picaxeforum.co.uk/showthread.php?18940-USB-communication-and-power&highlight=Goeytex+CP2102
I decided to measure voltages with the following results,
USB to Board: Connected, Power Supply to Board: Connected
board gnd to USB TXD: 3.3V
board gnd to USB RXD: 3.3V
board gnd to USB gnd: 0.0V
board ground to board Vin: 3.3V
board gnd to Picaxe gnd: 0.0V
board gnd to Picaxe VCC: 3.3V
board gnd to 74HC14 pin 1 A1 (from USB TXD): 3.3V
board gnd to 74HC14 pin 2 Y1 (to Picaxe serrxd): 0.0V
board gnd to 74HC14 pin 9 A4 (from Picaxe sertxd): 0.0V
board gnd to 74HC14 pin 8 Y4 (to USB RXD): 3.3V
board gnd to 74HC14 pin 7: 0.0V
board gnd to 74HC14 pin 14: 3.3V
other 74HC14 pins: NC
USB to Board: Connected, Power Supply to Board: DISCONNECTED
board gnd to USB TXD: 3.2V
board gnd to USB RXD: 2.5V <--- ????
board ground to board Vin: 0.0V
board gnd to Picaxe VCC: 2.5V <--- ????
board gnd to 74HC14 pin 1 A1 (from USB TXD): 3.2V
board gnd to 74HC14 pin 9 A4 (from Picaxe sertxd): 0.5V <-- ????
board gnd to 74HC14 pin 8 Y4 (to USB RXD): 0.0V
board gnd to 74HC14 pin 14: 2.5V <-- ???
I posted a question on Yahoo Groups Electronics_101 about this behavior and received the following answer,
Quote:
"Many devices will conduct from their I/O pins to their supplies. The 2.5V is a
common voltage when this is happening - it is a diode drop (about 0.7V) plus
some IR drop down from the 3.3V supply that is driving the other pins."
What I would like to do is have the ability to turn off power to the shield and shut it down completely without removing the USB cable. Will a switch on the power and a couple of transistor switches for the USB TXD, RXD lines work here?
Baxter
Baxter
