What Programming Editor is indicating is that something in your program will require a PICAXE which has later than version 7.4 of the firmware. This is because what you are trying to do in your program will not work with the firmware version of the PICAXE you have.PE comes up with a messaged that it needs a 28x with > 7.4 Firmware.
That's why I am needing a early version of PE.
Thanks. That seems the likeliest candidate as I can get a "requires firmware >= 7.4" error when downloading a program using more than 16 GOSUB's into an earlier version, and none of the other changes would likely generate a 7.4 related message.V4 ADDED 256 GOSUB OPTION
