I think there's a print error in the manuals regarding pulsout command
From manual page 19:
"The time is in 10ms intervals, but for easier reading, the text area in the command converts this to milliseconds as the time is entered into the command."
Manual 2 page 4 says 10 micro s (seems to be correct):
"PULSOUT pin,time
- Pin is a variable/constant which specifies the i/o pin to use.
- Time is a variable/constant which specifies the period (0-65535) in 10us units
(at 4MHz resonator)."
It doesnt seem to convert to ms as stated in manual 2 either.
I've spent hours trying to get a device working by increasing the pulseout value step by step but even setting it to 1000 didnt do much when should have been around 10 000
"PULSOUT pin,time
