PC to Picaxe to load external eeprom
This is what I've used to download text files to up to 4K eeproms--a lua program on the PC which writes 16-byte chunks with pauses between chunks, and a picaxe program.
The only particular trick in the lua program (after you get lua set up on the PC) is this which inserts the pause:
m = 1, 11 do
os.execute("dir > nul") -- delay for a while
end
For PCs faster than the one I was using, "11" needs to be increased, perhaps by a lot.
The picaxe program contains some extraneous stuff, because the eeprom was on an RTC module and I was testing the clock as well. If your program isn't text, you'd have to convert it before sending it.
I don't think that squirting the text out with HyperTerminal or PuTTY would work, because characters would be dropped after each 16-byte write. Maybe at a very slow baud rate it would work.
Remove the ".txt" extension to make the lua and bas files.
