Some help/advice please.
What is the easiest/simplest way to pass 1 word (2 bytes) between two PICAXE controllers, one of them being an 08M2? Actually, only the data going TO the 08M2 needs to be 2 bytes - going back the other way just needs to be a signal of some sort to note task completion. I guess this could be just raising an output pin high to generate an interrupt on the other controller. Would Serout/Serin work? I don't want to waste a lot of time if I'm barking up the wrong tree. Thanks for any input/advice you could offer.
