28X1 or 28X
I've got a 28X picaxe kit with an external 4Mhz resonator. i need to run at 8Mhz and don quite understand setfreq command. Will I need to change the external resonator? Can I use the internal resonator & get it to ignore the external one? thanx
Is it a PICAXE 28X1 as per the post title or a 28X as per the words of the post?
For the 28X1 (but not the 28X) use the command
SETFREQ m8 to operate at 8MHz using the internal resonator/clock. No neet to use/change the external resonator as it has an internal resonator. But note that there is provision to use an external resonator if you wish.
The SETFREQ command is not available for the 28X. As
IWP says and as per page 145 of the microchip PIC16F873A datasheet, the 28X always requires an external resonator or other suitable external circuit).
That would explain why the AXE022 proto-board comes with a 4MHz resonator as standard. If that is the board you have, then just solder in an 8MHz resonator and move the two jumpers on the proto-board.
