I have a 20M2 picaxe based memory tester that functions correctly in simulation.
My concern is I must ensure that my '-chip select' line does not go to a logic "0" during power up of the hardware, or it will invalidate the test.
I believe that all pins are configured as inputs at startup.
I have used a 5k pullup on the -CS line to ensure it initially follows the positive supply during powerup.
Picaxe +V supply ---/\/\/\/\---- Pin C.7
All other pins just wire across to DUT
I then use HIGH function to set it as an output, and a "1" -- but is this glitch-free in hardware, or is there a better solution?
Phil
edit: schematic and code added as requested
High C.7
