Opto slot interface
cadcamboss
Hi all
I am trying to construct an opto slot interface for controlling a motor driven mechanism. can't find a circuit anywere. can anyone help?
papaof2
Are you trying to detect the presence/absence of something in the slot (limit switch) or count pulses from a slotted wheel turning in the slot?
Presence/absence could be as simple as checking an input pin for high/low. Counting pulses is likely to be more complex.
Tell us more.
John
Tom2000
Hi all
You might try the circuit below.
The exact resistor values will depend upon your specific opto interrupter. If you can't find a data sheet, try 470 ohms for the LED current limiting resistor and 4k7 for the collector load resistor.
With nothing in the slot, the circuit will output a low to the Picaxe. With the light path interrupted, a high.
Good luck!
Tom
Andrew Cowan
count, pin, time, variable
count, 2, 2000, w0
serout 7,N2400,(#w0)
pause 8000
serout 7,N2400,(254,255)
Made that up - not sure if I got the LCD code right.
A
