This circuit made on through hole stripboard houses 2 picaxe 18M2 controlling 4 L293D driving linear motors, steppers and a mini servo. More details are on each of the two programs attached along with a pdf the block diagram and circuit diagram.
I have yet to finally finish, paint and semi-fit the crane to the decking of a model tug boat that I'm building and no doubt there will be some tweaking at the end.
It is not waterproof so only very calm water.
I wanted to see if I could indeed get the picaxe to read the 1 to 2mS pulses every 20mS that appear from the receiver outputs. I achieved this and should work on most radio control kits although with some small changes to the pulsout values. I happen to be using my Futaba.
The steppers are only 8mm in diameter and I attached them to a 2.5mm threaded rod via a rubber sleeve. The rod passed through a semi fixed nut on the small Arm 2 and the pivot sections. The wires are very tiny indeed to solder. The main arm Arm 1 and main moving body parts are a bit larger but still caused design and build problems - basically very fiddly.
The crane is made from plastic so not that strong.
I spent many hours trying to get it to work until I tried using suspend and resume which gave sections of program a chance to operate without interruptions. I actually wrote an automatic program that carried out lifting, rotating, extending actions which worked no problem but when I added it to this manual mode it didn't work well even with suspend etc so I removed it.
As it's one of my first posts I welcome comments of any improvement to layout, descriptions, coding etc I could make.
Oh the Steppers are bipolar 2 phase 4 wire drawing about 165 - 165mA and I didn't fit resistors.
