I don’t know much about op amps. I think though they will be suitable for this application.
I’ve got (or I will have in a bit, but I know exactly how it will behave) a 7x7 array of LDR’s, acting as a target, with the intent of sensing a laser.
The way I have the LDR's wired is the crucial bit...
One pin from each LDR is connected to +VCC. The other is connected to two signal diodes. One diode is connected to the common ROW wire of that particular sensor, the other diode is connected to the common COLUMN wire of that particular sensor.
This means the grid has 14 outputs and 1 input (VCC).
If the laser light falls onto the centre target (grid reference 4,4) then output 4 of the row outputs will go high(er) and output 4 of the column outputs will go high(er).
The problem is that these outputs are very analogue, and depend on ambient light levels. No PICAXE has 14 ADC’s so I need to use the digital inputs. This would be fairly easy you might think. “Simply connect each input to a digital input on a 40X. Connect some grounding resistors to each pin and tune their values until it works”. This will however need lots of precise setting up and will need setting up every time, due to changing light levels.
An op amp would oblitorate the analoge problem. As I know an op amp can be used as a comparator. The inverting input is compared with the non-inverting. The non inverting would be set to a fixed, preset voltage so that the system works. I have my own idea of an op amp I need so what I want to know is if there is such an op amp:
It would have one non-inverting input. This pin would be connected (via diodes) to all the output pins and would thus maintain a mean voltage of all the pins and could be compared with each individual pin.
It would have 14 inverting inputs. Each would be connected to one of the sensor outputs.
It would have 14 outputs. Each would correspond to each of the 14 inputs.
Now I know it is slightly unlikely that such an op amp exists . I know very little about op amps and their varieties and was hoping someone could point me towards the closest thing to this.
