Jon, could you elaborate a little more please?Hi All,
I have a problem, i have used up all my outputs bar one, and i need to control two enable inputs on another chip. What i really need is a chip that takes one control signal and switches between to outputs, so i can use both high and low of my last output pin?
Thanks,
Add an 08M to the circuit?well, basically i have one pin left on my picaxe which is controlling a RS485 comms chip, it has RE (read enable) and DE (Drive enable). However, only having one pin left means i cannot enable both, i can only hard wire it to one. Therefore, i am wondering if there is a chipset out there which switches between two outputs when its input is high or low.
That would mean i could use my last remaining output to switch the two enables?
Perhaps it would be easier if you posted bothwell i was hoping there was a more logic level way of doing it, as it is a bit of a waste of a microprocessor....
Correct, in fact if the Rx and Tx are going to seperate pins on the Picaxe you don't really have to disable the receiver, but unless you want to read the line while transmitting (say to detect bus clashes) you may as well just connect RE and DE together.Reading that i would assume that i can use one pin, DE, to both read and write. So DE high would enable the driver output, but making it low would enable the receiver input. Is this right?
