OLED and Freq
the old fart
Hi Guys,
expect this is easy, for those who know.
Chip 20X2
OLED AXE 134Y
Pin A.0
I've a program that switches between 4Mhz,8Mhz,16Mhz and 32Mhz.
I can output to oled:
@8Mhz serout a.0,N2400,(245,128,"sample 8Mhz")
@16Mhz serout a.0,N1200,(245,128,"sample 16Mhz")
I can't get 4 or 32 Mhz to work,
I've read about N2400_4 etc, but nothing works.
TOF
jims
Hi Guys,
Chip 20X2
OLED AXE 134Y
Pin A.0
I can't get 8 or 32 Mhz to work,
TOF
I've had the same situation with the AXE133Y serial OLED and found that it only works on M4. It skips over other frequencies as if the OLED didn't even exist. Jims
8MHz is the default clock on a 20X2, so use either
or
serout a.0,N2400_8,(245,128,"sample 8Mhz")
16MHz is twice as fast, which is why default N1200 (expects 8MHz ie N1200_8) x2 = 2400 still works. However it would be better to write
serout a.0,N2400_16,(245,128,"sample 16Mhz")
etc.
the old fart
or
etc.
Hi Technical,
opps meant 4Mhz and 32 Mhz not working.
n2400_4 for 4Mhz doesn't work for me.
n2400_32 does not exist .
Refer to the command summary for SerOut here. (Refer to the bottom-most table.)
However, you will see that it is not possible to output serial using the SerOut command at 1200 baud with the processor running at 16MHz.
The 1200baud option should be available (@16MHz) to you if you use the hSerOut command on the (specific) hSerOut pin. Refer to the hSerSetup command.
the old fart
Hi Inglewoodpete,
I found the table in manual2.
baud rate to OLED is N2400.
I can see now why 32Mhz will not work off A.0, needs to be C.0.
Why does the 4Mz n2400_4 not work?
Not sure; it works for me ...
#Picaxe 20X2
SetFreq M4
Pause 1000
SerOut A.0, N2400_4,( 254, 1 )
Pause 500
SerOut A.0, N2400_4,( 254, $80 )
For b0 = "A" To "P"
  SerOut A.0, N2400_4, ( b0 )
  Pause 500
Next
the old fart
#Picaxe 20X2
SetFreq M4
Pause 1000
Pause 500
For b0 = "A" To "P"
  Pause 500
Next
Thanks Hippy,
I'll investigate the M4 setup.
I can get readouts if I change back to M8 for the OLED, then revert back to 4 ,32 or even 64MHz.
Don't know if that's acceptable programming, but it works.
TOF
