shaunchivers
Appologies up front if i am being thick but i really am running out of idea's on this one and am starting to think that I may have damaged the AXE033.
I have connected the Datalogger (AXE110) to the LCD AXE033 as follows:
AXE110 AXE033
GND ----> 0V
OUT6----> IN
V+ ------> V+
I am using 3x AA batteries (new Duracell's) to power the AXE110 which then bridges across to the AXE033. As per the datasheet instructions, due to the 4.5v supply J2 on the AXE033 is connected to bypass D1.
Now, if I short the CLK pins on the AXE033 i see text on the LCD screen so i know that the screen is ok.
If i use the Programming Editor Wizard to download a basic temperature mission using the AXE033 as an output and monitor the 'IN' on the AXE033 with a multimeter i can see a pulse of +5v (ish) when the program is downloaded but i see no display on the LCD.
I see that some posts say that the AXE033 supports N2400 and not T2400 formatted data so have tried this but still no display.
Have i done something wrong or am i missing something? The reason I mention about possible damge to the AXE033 is that i initially had the 'IN' and '+V' swapped. Therefore +4.5v perminantly on the serial input.
Any help or advise would be greatly appreciated.
AXE110 AXE033
GND ----> 0V
OUT6----> IN
V+ ------> V+
