Hi guys, I've been reading this forum for quite some time and am very impressed with the knowledge available and advice freely given. <grovel grovel>
I'm trying to set up an ID12 rfid reader to read glass rfid tags attached underneath 'N' guage model railway rolling stock. The idea is to place the reader at the entrance to a station and have an LCD display information on the approaching train. On a different part of the layout I want to use a second ID12 reader to activate sound files using the mp3 player Haku originally found.
The code I have cobbled together at the moment doesn't work as intended. It reads the tags and cards I have at the moment, correctly... but only on the second swipe for some reason. If I then swipe a different card/tag, again, it will only display it (using debug) after the second swipe. Also I originally tried to use a quallifier on the serin command, this just screwed everything up. The resulting ascii string received had no bearing on the string expected.
Part of the code used has been lifted from this forum but it's my first foray into the 'bptr' commands.
The part between check: and loop doesn't complete for some reason.......
any ideas anyone
cheers, Steve
' last used on 18m2
' ** rfidtest.bas **
' Picaxe 18M2 and ID12 rfid reader
' Data format is "supposed" to be ......
' STX ($02) Data (10 ascii) Check sum (2ascii) CR LF ETX ($03)
' The 1byte (2 ASCII characters) Check sum is the
' “Exclusive OR” of the 5 hex bytes (10 ASCII) Data characters.
' "I" get the STX ($02) and use it as a qualifier. I also get the LF ($0A) and ETX ($03).
' I get 10 hex data bytes and 2 hex checksum bytes, no sign of a CR which should be $0D
' ** Data **
eeprom 0, (50,57,48,48,57,52,50,49,49,69,1) ' "290094211e" card with label last digit on
eeprom 11, (50,57,48,48,57,52,50,49,49,69,2) '"290093fe68" card without each row is
eeprom 22, (48,48,51,54,53,70,56,57,52,55,3) '"00365f8947" tag item number
' i.e. at eeprom
' ** variables and constants ** 10,21 and 32.
symbol indexa = b21
symbol indexb = b16
symbol indexc = b17
symbol char = b18
symbol tag = b19
symbol cntr = b22
setfreq m8 ' set to 8mhz
serin B.0, n9600_8, b0,b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13,b14,b15
' NOTE b0 is used twice above to overwrite the start byte ($02)
setfreq m4 ' reset to 4mhz
debug b0 ' display characters
check:
cntr = 0
for indexa = 0 to 22 step 11
bptr = 0
for indexb = 0 to 9
indexc = indexb + indexa
read indexc, char
if @bptrinc <> char then exit
let b23 = bptr
if indexb => 9 then
cntr = cntr + 1
' read indexc, b20 ' debug only
' tag = b20 ' debug only
' read indexc, tag
next indexb
if cntr <> 0 then exit
next indexa
tag = cntr
' pause 1000
any ideas anyone
cheers, Steve
