Greetings, am investigating use of PicAxe for wind power generation load control (increase load on generator as wind speed increases and decrease as speed drops to maximize output). I would like to meter rotation speed and wind speed simultaneously using the Count instruction and the multitasking capabilities of the M2 chips but am wondering if it will just complete the Count in one task before going on to the Count in the other (sequential vs simultaneous). I was quite excited to see the M2s support "multitasking" but it would appear the capability is quite rudimentart insofar at least as real time processing is concerned(?).
I would also like to meter the two speeds continuously all the while responding to IR input and transmitting data over the serial output. Since both those functions apparently stop other processing whilst running and, as I understand it, even disable interrupts, I cannot see how continuous counting can be accomplished with a single chip. So, then I looked at the possibility of using multiple chips communicating via 12c but cannot determine whether or not 12c communication has the same limitations as serial communication.
I have also noted, using the programmer, that The M2 chips do not seem to support acting in 1c2 slave mode (master mode only) although this seems to contradict the documentation on the h12csetup command. Is that actually the case?
One other question if I could. If I use pwm to control power going to the wind mill load(s), will the IR or serial instructions interfere (alter timing) with the pwm output(s)?
Thanks for any help and suggestions on how I can accomplish this.
