PICAXE is great. I just finished my first project and I'm very pleased with the results.
I've always wanted to build a bank that would display the number of coins and the value. Not only for each coin but a bank total as well.
I have 4 optical sensors to detect the coins, 4 buttons to select which coin count/value to display, a subtract button which is used in conjunction with the other 4 button, and a `Bank Robbery` button - triggered when the lid of the bank is removed. Of course it has an LCD display. Without any buttons pushed the LCD displays the total number of coins in the bank and the total value. All of this using an 18x chip - which is also the only chip I used. All input, except the subtract button, produce an analog value which is read by a single pin. The subtract button uses a seperate pin for 2 reasons. Fist it is used in conjunction with the other buttons - so it couldn't be just another analog value. Secondly it calls an interrupt routine which does the subtracting.
When the lid of the bank is removed the LCD displays the message, `Bank Robbery - Stop Thief`, and it flashes an LED. I have a spare output which I want to connect a small speaker to - for a siren effect during the bank robbery routine.
Â
Â
