You cannot have two AXE033 LCD modules working in i2c comms mode connected to the same i2c bus as they both have the same address which would lead to conflicts when ever anything else tried to communicate with them.So if I want 2 picaxes that both have an lcd attached to them, then I cannot get them to talk to a single shared eeprom on the i2c bus then...
so, as multi-master is permitted, it should work.The multi-master capability of the I2C-bus allows rapid
testing and alignment of end-user equipment via
external connections to an assembly-line
