PeterMooney
I'm trying to replace an old points based motorcycle ignition by using Hall effect trigger and PICAXE18M2 to provide variable advance/retard intervals. I have tried "pulsein" and "pauseus" hoping to get intervals of about 0.12 milliseconds but the interpreted Basic on the chip seems to be way to slow - taking half a second to respond.
Can't the 18M2 manage these millisecond response speeds?
Here's a snippet of code...
/*code*/
pulsin c.7,1,w1 ; look for pickup low to high transition and store time in w1
;now check this time interval against the retard table...
;if no high to low transition or longer than 0.64 second then w1=0
select w1
case = 0 ;rpm < 500 so full retard 36 degrees
retardDelay = 12000 ;36 degrees
case < 7317 ;rpm > 4100 so full advance
; do nothing go make spark
retardDelay = 0
case < 7895 ;rpm > 3800 so delay 0.132 millisecs
retardDelay = 132 ; 3 degrees
case < 8571 ;rpm > 3500 so delay 0.286 millisecs
retardDelay = 286 ; 6 degrees
case < 9375 ;rpm > 3200 so delay 0.469 millisecs
retardDelay = 469 ; 9 degrees
case < 10345;rpm > 2900 so delay 0.690 millisecs
retardDelay = 690 ; 12 degrees
case < 11538;rpm > 2600 so delay 962 millisecs
retardDelay = 962 ; 15 degrees
case < 13043;rpm > 2300 so delay 1.304 millisecs
retardDelay = 1304 ; 18 degrees
case < 15000;rpm > 2000 so delay 1.750 millisecs
retardDelay = 1750 ; 21 degrees
case < 17647;rpm > 1700 so delay 2.353 millisecs
retardDelay = 2353 ; 24 degrees
case < 21429;rpm > 1400 so delay 3.214 millisecs
retardDelay = 3214 ; 27 degrees
case < 27273;rpm > 1100 so delay 4.545 millisecs
retardDelay = 4545 ; 30 degrees
case < 37500;rpm > 800 so delay 6.875 millisecs
retardDelay = 6875 ; 33 degrees
else ; rpm < 800 so delay 12.000 millisecs
end select
pauseus retardDelay
makeSpark:
;now make_spark
;break LT circuit
high B.0
'delay for dwell
if w1 = 0 then
dwellLength = retardDelay
dwellLength = w1/2 ;1/4 revolution (90 degrees)
pauseus dwellLength
low B.0 ; close LT circuit again
/*code */
Where am I going wrong?
/*code*/
select w1
retardDelay = 0
end select
pauseus retardDelay
makeSpark:
;now make_spark
;break LT circuit
high B.0
'delay for dwell
if w1 = 0 then
pauseus dwellLength
/*code */
